pateltarunt
I have my product item data table in Sheet.2 that contain my product item number-name-sales data etc.
I have create another sheet.1 for getting different search result from main data sheet table in Sheet.2
I want to delete Product item based on item number. For that If I enter Item number in Sheet.1 and hit delete button this command go into sheet.2 (Data entry sheet table) Item number column and search for that item then select complete row and then delete it and come back to my Sheet.1.
I have create the below macro but it will not select the Product item row and hence delete of item is not perform.
>>> use code - tags <<<
Please check it and give correct code.
>>> use code - tags <<<
Dim abc As String
abc = Sheets("Sheet.1").Range("G5")
Sheets("Sheet.2").Select
Set Rng = Columns("A:A").Find(What:=abc, _
LookIn:=xlFormulas, LookAt:=xlWhole, SearchOrder:=xlByRows, _
SearchDirection:=xlNext, MatchCase:=False, SearchFormat:=False)
rownumber = Rng.Row
ActiveCell.EntireRow.Delete Shift:=xlUp
Range("A2").Select
Sheets("Sheet.1").Select
Range("G5").Select
