vba script for date difference between two columns
abhi_jain80
Hi folks,
I need to calculate the date difference between the two columns A and B and store the value in C column. There are around 100k rows and some missing dates in the B column. Here is the vba code I am using...it is absolutely working fine what I need but taking around 15 mins to run on my machine. Just thinking, if there is any better optimized way to do the same? Thanks in advance...
>>> use code - tags <<<
Sub DateDifference()
Dim FD As Date
Dim LD As Date
Dim LR As Long
LR = Range("A" & Rows.Count).End(xlUp).Row
For i = 2 To LR
FD = Range("A" & i).Value
LD = Range("B" & i).Value
If Range("B" & i).Value = "" Then
Range("C" & i).Value = ""
If DateDiff("d", FD, LD) <= 0 Then
Range("C" & i).Value = 1
Range("C" & i).Value = DateDiff("d", FD, LD)
Hi,​
according to any Excel forum rules you forgot the link(s) of other forum(s) where you already have created the same thread !
And use the 3 dots icon when posting any code here …​
Ok, thanks.​
Did you try at least a formula which is often faster than any bad looping cell-by-cell code ?​
