I am "new-ish" with Macros... I am working on getting about 300 PDFs renamed and moved into appropriate folders.
I have macros set-up to get the file names, rename the files and create folders, but I can not figure out how to move or copy the files based on the file path that I have indicated for the specific PDF. Everything I find online shows moving files from one folder to another, but I need to move these PDFs from 1 folder into 300 uniquely named folders.
I need something that can tell excel to Move Files (or copy files) , current path (or xDir) I want to set to "C:\" for a prompt to choose a folder and I want to set the file names (from column B) to be SelectedItems and then move or copy to the folder path that I have indicated in Column C.
My spreadsheet is set-up as shown below (current folder path = Desktop)
Column A=Old File Name (ran macro "GetFiles")
- i.e. Reg 123 Survey Reprt October.pdf
Column B=New File Name (ran Macro "RenameFiles"
- i.e. October Survey - Region 123.pdf
Column C = new folder path (each "region" has it's own folder)
- i.e. C:\Reports\October\Region 123
C:\Reports\October\Region 234
C:\Reports\October\Region 467
