sumit Madaan
I want to lookup between two workbooks sheets through vba macros on basis of common field between both. i am using below code and it is showing error, snapshot attached for your ready reference.
please help and advise. Thanks in advance.
I need result in sample macro2 file and need to do lookup from BB_Finacle ID-Mar'19 file.
Sub test()
Dim sw As Workbook
Dim dw As Workbook
Dim srng As Range
swname$ = "BB_Finacle ID-Mar'19.xlsb"
swpath$ = ThisWorkbook.Path & "\" & swname
Set dw = ThisWorkbook
c& = Sheet1.Cells(Rows.Count, 1).End(xlUp).Row
Workbooks.Open (swpath)
Set sw = Workbooks(swname)
Set srng = sw.Sheets(1).Range("B:R")
Sheet1.Range("B2:B" & c).Formula = "=VLookup(A2,[BB_Finacle ID-Mar'19.xlsb]SHEET1!" & srng.Address & ", 3, False)"
Sheet1.Range("B2:B" & c).Copy
Sheet1.Range("B2").PasteSpecial xlValues
sw.Close
