VBA Macro for copying multiple column in one column with condition
Nishant859_1
Good Evening Experts,
Hope you all are doing well & safe !
Looking help with VBA code to copying multiple column in one column
but there is condition i.e. Column 1 & Column 2 required in repetition & also required header
for detail understanding i am attaching workbook, Raw Tab contain Data, & Output is the tab which is required thru Code
Output tab in attached file is linked with Raw data just to better understanding, but actually data not required to Links.
Small Example
Raw Data
CentreFunctionHeader 1Header 2Header 3
APPRO
100​
244​
30​
EMSAA
112.3​
33.7​
NAMFAC
126.1​
OUTPUT is
CentreFunctionHeaderAmount
APPROHeader 1 100.00
EMSAAHeader 1 112.30
NAMFACHeader 1 126.10
APPROHeader 2 244.00
EMSAAHeader 2 -
NAMFACHeader 2 -
APPROHeader 3 30.00
EMSAAHeader 3 33.70
NAMFACHeader 3 -
Nishant859_1
Thanks a Lot
Nishant859_1
Select Output-sheet to get results.
I left You data there too.
Was there any reason - why Header 20 was twice?
... I skipped that.
Thanks a Lot Ninja, Need Header 20 one time only
can we link VBA code macro button in a separate sheet
when we click button code will create a new sheet with output data
vletm
Nishant859_1
About 20 ... wonder was ... why?
About linking ... It won't give expected result - it uses fixed sheet-name.
About clicking ... where is that a separate sheet?
>> Now, You could test this way
... copy ( = duplicate ) Your Output-sheet manually as many times as need
... always then You'll activate Your sheet - it'll refresh its output - if You'll confirm it.
... The file updated
Nishant859_1
Seems You've forgotten/skipped few basic steps ... based #5 reply
- take care.
Marc L
Why don't you use a pivot table ?​
And far above all, why did you open the same thread on another forum ?‼​
A must read :​
