VBA macro Copy Paste formula instead of Values only
>>> use code - tags <<<
Sub CopyPaste()
    'Declares Varibles
Dim copyRange As Range, pasteRange As Range
'Sets where were are coping from
Sheets("Product").Select
Set copyRange = Range("A1:H51").CurrentRegion
'Filter for anything over 0
Range("G1:G51").AutoFilter field:=1, Criteria1:=">0"
'Copy only filtered rows and paste in AA1
copyRange.SpecialCells(xlCellTypeVisible).Copy Range("AA1")
'Turn off filter
ActiveSheet.AutoFilterMode = False
My problem is that when I run the macro it copy paste the formula's to AA1 aswell. I only need it to copy the values.
Chris
  • Jacques v1.xlsm
Hi vietm
I need your help again, PLEASE !
I refer to my attached file, sheet Audit_Trail.
I am looking for a VBA code that will only Print the data in my Audit_Trail sheet (Column A:G) and/or ( Column I:M) for the last date or for the period between two dates.
Can you please help or direct me to a article covering this.
Chris
