I have a text file which has large strings of information inside, however I am only looking to extract small pieces of info out. The numbers that should be extracted is color coded and should output into 4 columns.
What's the quickest way to go about doing this?
Source data is in a text file, but can be put into excel if its easier for the macro:
This text string (3 rows) repeats for about 800 times.
Thanks in advance!
Column 1 (Max HC, usually 2 digits): ##
Column 2 (Actual HC, usually 1 digit): #
Column 3 (Units Requested, variable number of digits): #.###
Column 4 (Units Delivered, variable number of digits): #.####
Row 1: Bionic> 118390: DEBUG unit_deliver(): <Unit> Expected Max HC=12
Row 2: 119157: INFO unit_deliver(): <Unit> started delivery of 0.002 Units (0.020 uL) (timeout_ms 9688 msec)
Row 3: 121157: INFO unit_deliver(): <unit> total delivery amount=0.0190 uL, hc=6
Thanks in advance!
