VBA isnumber(match()) formula
tomas
Hi
I need a makro which can apply a formula in c column for each row which has corresponding entry in column B. I recorded makro but it's for statis range and can't find out how to do it dynamically
thanks
tomas
You need to Upload a Sample file
with clear rule
which would explain
needed result.
sorry I forgot. Column B should contain 1 additional record to column A but number of rows will differ so It will differ also for column C which has the formula in
  • test.xlsm
tomas
I would do it this way - without formulas...
Edit something within A&B-columns ...
  • test (1).xlsm
tomas
Didn't You ask a macro which would do something?
Do that file give needed results?
~'to check, if b-column values can find from a-column'
... after that, the next step could be to understand it.
tomas
I also show that Your macro ... and I didn't use it as I wrote.
There is one more macro in 'Sheet1'.
Did You test as I tried to ask that file? to verify do it work?
