VBA help...
Hello, Please let me know if there is anything wrong in the below code. Because after updating the file I have to press F2 to get the desired result. It does not update automatically which I want. Kindly advise.
Jay
-----------------Code-------------
Function Colorfunction(rColor As Range, rRange As Range, Optional SUM As Boolean)
Dim rCell As Range
Dim lCol As Long
Dim vResult
lCol = rColor.Interior.ColorIndex
If SUM = True Then
For Each rCell In rRange
If rCell.Interior.ColorIndex = lCol Then
vResult = WorksheetFunction.SUM(rCell, vResult)
Next rCell
vResult = 1 + vResult
Next rCell
Colorfunction = vResult
End Function
When you say you're updating the file, does that involve changing the numbers, or just coloring some cells? If the former, we may be able to help by adding the line
Application.Volatile
to the beginning of code. If it's the latter, we're stuck, since simply changing the format of cells doesn't trigger an event or a recalculation. =/
I do both. updating the numbers and changing the color also. but when I copy paste the format from below cell or press F2 then the formula updates.
Any solution?
Jay
Hi Jayadev,
It will be helpfull for us.. if you provide us the Complete Background Information for the query.. :)
http://www.ozgrid.com/VBA/sum-count-cells-by-color.htm
http://www.excelforum.com/excel-formulas-and-functions/456045-sum-by-fill-color-2.html
http://www.teachexcel.com/excel-help/excel-how-to.php?i=318095
http://www.brainbell.com/tutorials/ms-office/excel/Count_Or_Sum_Cells_That_Have_A_Specified_Fill_Color.htm
and finally..
Be aware that the changing of a cells fill color will not cause the Custom Function to recalculate, even if you press F9 (Recalculates the whole Workbook). You will need to either, select the cell and re-enter the formula, or go to Edit>Replace and replace = with =, or use Ctrl+Alt+F9
Try also to avoid the use of Application.Volatile as it will not help in this case and only slow down Excel's calculation time.
from PARENT Original Post..
Deb
If there is a solution, I can't think of a good one. =/
Is it possible to live with a delay? Maybe add a button or something that forces a recalc and verifies then that the data has been "updated"?
EDIT: Thanks Deb, for finding the background, (would have) saved me a bunch of time. =P
