VBA help to save a download file to a specific location
riyaj
Hi Guys,
Please help. I am new to VBA macro's and want to prepare a macro which will
1. take a path from excel cell ,
2.open internet explorer , (please note here, I have hypelinks path which will download as I navigate to asked path),
3.and it will save downloaded file to specific folder path mentioned in excel cell.
Fortunately I have now a macro which can do first 2 steps but I am struggling to work for 3rd step. Could you please help me ?
Here's VBA macro I have for your reference:
Const MyUrl As String = "http://orbitobi.nat.bt.com/analytics/saw.dll?Download&Format=excel&Path=/users/XXXXX/AHT%20data"
Dim ie As Object
Set ie = CreateObject("InternetExplorer.Application")
ie.Visible = True
ie.navigate "http://orbitobi.nat.bt.com/analytics/saw.dll? ownload&Format=excel&Path=/users/XXXXX/AHT%20data"
' Here Internet asks for location to save file or open a file. I need to choose save and location here
While ie.busy
DoEvents
Wend
Set lform = ie.document.forms(0)
With lform
Set txtPassowrd = ActiveSheet.Shapes("TextBox2").OLEFormat.Object
Set txtEIN = ActiveSheet.Shapes("Textbox1").OLEFormat.Object
lform.Item("user").Value = txtEIN.Object.Value
lform.Item("PASSWORD").Value = txtPassowrd.Object.Value
'Application.Wait Now + TimeValue("00:00:04")
lform.Submit
ie.document.all.Item("YES").Value = "Yes"
ie.document.all.Item("YES").FireEvent ("onClick")
lform.Yes
Please let me know if you have any more questions to clarify..
Marc L
maybe with an API function :
[pre]
Declare Function URLDownloadToFile Lib "urlmon" Alias "URLDownloadToFileA" _
(ByVal pCaller As Long, ByVal szURL As String, ByVal szFileName As String, _
ByVal dwReserved As Long, ByVal lpfnCB As Long) As Long
Sub Example()
DownloadFile$ = "here the name with extension"
URL$ = "http://here the download website address/" & DownloadFile
LocalFilename$ = "here the drive and download directory" & DownloadFile
MsgBox "Download Status : " & URLDownloadToFile(0, URL, LocalFilename, 0, 0) = 0
[/pre]
riyaj
Hi Marc,
Your code and solution is brilliant. Many thanks for your prompt responce !
Was little worried if you could help me here, as when I added Website address , path and name of sheet to download, it gives me error as RUN TIME ERROR 13 - TYPE MISMATCH
I googled about it, but no success yet. Showing you macro which I added into excel sheet --
Sub Download()
DownloadFile$ = "AHT.xls"
URL$ = "http://orbitobi.nat.bt.com/analytics/saw.dll?Download&Format=excel&Path=/users/606823201/AHT%20data" & DownloadFile
LocalFilename$ = "C:GenesysAutomation" & DownloadFile
Please note , when I click debug it highlights line - MsgBox "Download Status : " & URLDownloadToFile(0, URL, LocalFilename, 0, 0) = 0
Could you please assist ?
Marc L
Check yours ‼   You didn't pay attention to the last slash or backslash …
riyaj
Thank you Mark ,must be missing the same thing.
I am not on my desk at my desk so Apologies I could not find if your solution is right, but I am sure you are pointing at correct thing :)
The website that I was trying to download data needed a Login ,password for obvious reasons. As our code does not need IE to start , I could not add login password here.Is is possible to add a code which will add them?
Marc L
The login need is the point you should start your subject with …
And in this case I hadn't post an answer …
So you have to pilot IE and it's not easy for a VBA newbie !
You must do a research and learn how to pilot IE …
SirJB7
Excel Rōnin
Hi, riyaj!
Give a look to these links:
http://chandoo.org/forums/topic/bring-to-front-macro
http://dailydoseofexcel.com/archives/2011/03/08/get-data-from-website-that-requires-a-login/
The first is a simple IE object pilot example, the last one deals with UserID & Password.
Regards!
PS: But as Marc L correctly stated, for newbies to VBA it'd be either funny or hardly painful, depending on your sense of humor.
dharmendrashah
dear riyaj,
if you succeed to create above excel sheet... please share... i am also want to do same...
i am using hyperlink to download data from excel sheet...but it saves on default folder or specify in browser setting...
thanks
heavican03
[pre]
Sub Example()
[/pre]
This code works absolutely perfect for me once I deleted the "Download Status" part. Now the problem is though I don't want the msgbox because I just want to run it and not have a user do anything. If I remove the MsgBox though the code no longer works. I don't understand code and I can't figure out why it is the case but with the MsgBox command it works perfect without it, it doesn't save the file. Is there another command I could use.
