Hi Folks,
I am stuck with a bit of EXCEL 2003 VBA problem. It might be easy and simple for all of you. Spent lots of time searching solution on web but could not find any code that satisfy my need. I need VBA code, so I can run macro with command button.
I get lots of text files that we open in excel and consolidate data before it is used. Excel workbook can have many sheets with separate data. Titles of each columns is this:
Col A=Date B=Total C=Max D=Min E=Average
In date column A, some of the dates repeat (more than one row of same date) and we need to consolidate/combine data in a single row till last row of data in each sheet. What I need is:
1. check Date in column A, if date does not repeat in next/lower line then copy
that row from range e.g. A7:E7, and paste it into column G7, ELSE
If date repeats in column A then:
a. copy date from Column A and paste it into Column G eg. Value of A3 into col G3
b. for this date e.g. A3:A6, Sum all values from col B3:B6, and put into col H3
c. for this date e.g. A3:A6, get maximum value from col B3:B6, and put into col I3
d. for this date e.g. A3:A6, get minimum value from col B3:B6, and put into col J3
e. for this date e.g. A3:A6, calculate/get average value from col B3:B6, and put into col K3
2. Do it till last row of data
3. Do it for each sheet starting from sheet 2
4. Output data should not have empty rows. After consolidation number of rows will be less than rows from RAW DATA e.g. sheet USO, col A has 184 row and col G:K has 168 rows.
Attached is sample excel file. in sheet USO and UNG, col A to E is raw data and
repeating dates are highlighted. col G to K is out put data that was done manually.
I am using EXCEl 2003. Hopefully someone will be out there to help.
If anything not clear, please feel free to ask.
Sorry deleted lots of data and sheets because file size was too big. There is enough data to do tricks asked above.
Riaz
Riaz
