I found the following code in exporting selected range into PNG.
It works well. However, the displayed image is a bit non-smooth, especially the font.
Is there a way to enhance the export resolution?
Thanks.
Thanks.
>>> use code - tags <<<
Sub CommandButton56_Click()
Dim vFilePath As Variant
Dim rSelection As Range
Dim sDefaultName As String
If TypeName(Selection) <> "Range" Then
MsgBox "Selection is not a range."
Exit Sub
Set rSelection = Selection
vFilePath = Application.GetSaveAsFilename(InitialFileName:="Clip", FileFilter:="PNG (*.png), *.png")
'--exit if cancelled by user
If (vFilePath = False) Then
Exit Sub
'-- copy selected range as picture (not as bitmap)
rSelection.CopyPicture Appearance:=xlScreen, Format:=xlPicture
'--Create an empty chart, slightly larger than exact size of range copied
With ActiveSheet.ChartObjects.Add(Left:=rSelection.Left, Top:=rSelection.Top, Width:=rSelection.Width + 2, Height:=rSelection.Height + 2)
With .Chart
' clean up chart
.ChartArea.Format.Line.Visible = msoFalse
' paste and position picture
.Paste
With .Pictures(1)
.Left = .Left + 2
.Top = .Top + 2
' export
.Export CStr(vFilePath)
' remove no-longer-needed chart
.Delete
