Hurr1can3Blu3
Need help with VBA code to make vlookup dynamic (2 workbooks) book 1 holds vlookup...books have daily changing filenames, book 1 is old master file....see current code below.
Sub todeleteaging1()
' todeleteaging Macro
Dim fd As Office.FileDialog
Set fd = Application.FileDialog(msoFileDialogFilePicker)
With fd
.AllowMultiSelect = False
.Title = "Please select the report."
.Filters.Clear
.Filters.Add "Excel 2016", "*.csv"
.Filters.Add "All Files", "*.*"
If .Show = True Then
FilePath1 = .SelectedItems(1)
ary = Split(.SelectedItems(1), "\")
TextBox1.Value = ary(UBound(ary))
Windows(TextBox2.Value).Activate
myFileName2 = ActiveWorkbook.Name
mySheetName2 = ActiveSheet.Name
myRangeName2 = Range("A1:A")
Windows(TextBox1.Value).Activate
Columns("T:T").Select
Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
Range("T2").Select
myRangeName2 = ActiveWorkbook.ActiveSheet.Range("A1:A").Address(RowAbsolute:=1, ColumnAbsolute:=1, external:=True)
Range("T2:T").Formula = "=VLOOKUP(T2, " & myRangeName2 & ", 1, FALSE)"
Range("T2").Select
Selection.AutoFill Destination:=Range("T2:T")
Range("$A$1:$T$").AutoFilter Field:=20, Criteria1:="=#N/A" _
, Operator:=xlOr, Criteria2:="=#N/A"
Range(Selection, Selection.End(xlToRight)).Select
Selection.Copy
Sheets.Add After:=ActiveSheet
Range("A1").Select
ActiveSheet.Paste
Range("C6").Select
ChDir "C:\Users\RRF - 113\Downloads"
ActiveWorkbook.SaveAs fileName:= _
"C:\Users\RRF - 113\Downloads\todelete20180413.csv", FileFormat:=xlCSV, _
CreateBackup:=False
