VBA - Array for hidden sheets with part names
vasim
I have a combobox in which there are months form Jan to Dec and 1 as All,
There are a total of 12 sheets named as Jan 2010, Feb 2010...till Dec 2010, now when I select Jan in combobox and go the Jan 2010 sheet opens, the only problem is when I click All and go all the hidden sheets do not become visible. Help please
Dim x As String
Dim y As String
Dim Wsname As Variant
y = "2010"
x = combobox1.Value
If combobox1.Value = "All" Then
Application.Worksheets(array("" * " & y", "" * " & y")).Visible = True
Application.Worksheets(x & " " & y).Visible = True
Unload Me
I know that the array is not working as the shets are hidden can i get some thing to solve....
Hui
Staff member
How about:
[pre]
Dim x As String
Dim y As String
Dim ws As Worksheet
y = "2010"
x = combobox1.Value
For Each ws In Worksheets 'This loops through each WSheet and makes them visible
ws.Visible = True
Unload Me
[/pre]
vasim
Thanks Hui, But I have many more sheets available, I want to make sheets visible only where there are months and 2010.
vasim
This is working for me... Just a single question Hui, if you want to macth part text in vba we can use "*" before the actual text? is this correct.
Dim x As String
Dim y As String
y = "2010"
x = combobox1.Value
For Each Wsname In Array("January 2010", "February 2010", "March 2010", "April 2010", "May 2010", "June 2010", "July 2010", "August 2010", "September 2010", "October 2010", "November 2010", "December 2010")
'For Each Wsname In Array("" * " & y", "" * " & y")
Worksheets(Wsname).Visible = True
Unload Me
Hui
Staff member
Dim x As String
Dim Yr As String
Dim ws As Worksheet
Yr = "2010"
x = combobox1.Value
If Right(ws.Name, 4) = "2010" Then ws.Visible = True
Application.Worksheets(x & " " & Yr).Visible = True
Unload Me
vasim
Ohhhh just a few second late, else my code could be shorter than the one I have anyway..I got to learn something new...thanks a lot Hui
vasim
Hello Hui,
This makes the sheet unhide, however I have one more condition where I have to make these sheets hide
If Right(ws.Name, 4) = "2010" Then ws.Visible = false
Why is this not working
Luke M
The latter line of code works just fine. However, your 2 conditions are identical, so in the end all sheets ending with "2010" are hidden. Was this the desired effect?
