VB Code to make DC in required format from system fetch data
Ateeb Ali
Dear Sir
One example file is attached.
It has 03 sheets;
System Extracted Detail: This form I get data from system
Conversion: This is just conversion of Article number into 03 different column which we need on sheet "Required Format"
Required Format: In this sheet, I have a button "do it", when we press it, I just need copy information from sheet "System Extracted Detail" like pivot table but Pivot table is not coming in that format, thats why I need VB solution.
I need empty two rows on each line (it is requirement by customer)
I will appreciate a lot if some one can help.
On DC, we will not show article number (which is internal), instead will show "equal to" column from sheet "Conversion"
PCI
Can you how is the final result
For example with 228309
from where is coming info about 914 Mtr ???
Sheet "Required Format" must be clean up or do we stick info at the bottom
PCI
You don't answer to the questions:
1 - Sheet "Required Format" must be clean up or do we stick info at the bottom ???
2 - with 228309 from where is coming info about 914 Mtr ???
Ateeb Ali
Dear Sir, may be my mistake, I could not explained in good way, let me try again.
Attached excel file;
It has 03 sheets.
Sheet "System Extracted Detail" this information extracted from system
Sheet "Conversion" this we will use for conversion like when there is article # 8009/3040, on dc, it will appear as "SSP" "21/3" "914 Mtr"
(See attached file, I have highlighted in Yellow)
Final result is DC detail like whenever system extracted detail is updated, DC will be updated, one solution I have also attached as Pivot table (see attached file for better understanding)
I really really appreciate your response and help and look forward for solution on this form which is always helpful for me
Ateeb Ali
Alternatively I make solution, see attached file
Just need to press "DO it" button to sort data then "Lets Go" to make delivery challan
since I am not good in vb, I recorded the code, so if someone can help to shorten the code so it work faster, also if possible to move grand total column after color and need 02 empty rows after every entry, is it possible?
