How do I highligh the entore Row of the current cell using macros?
I have used the below mentioned macros however they dont seem to working as per my need.
Union(Target.EntireRow, Target.EntireColumn).Select
Intersect(Target.EntireRow, Target.EntireColumn).Activate
If I use the above, the cell and its Row and Colunm is being highlighted in grey color.
Sub Worksheet_SelectionChange(ByVal Target As Excel.Range)
'Update 20140318 'Updated By dlsodders for
'Select Just Row
Static xRow
If xRow <> "" Then
With Rows(xRow).Interior
.ColorIndex = xlNone
pRow = Selection.Row
xRow = pRow
With Rows(pRow).Interior
.ColorIndex = 10
.Pattern = xlSolid
If I use this, then just that Row gets highlighted in Green, however any background colour to a Row gets removed.
Can anyone please help in writing a code that will just highlight the Row of current cell in light Grey color without removing the backgound color/fill ?
Thank you,
Nisarga.
'Select Just Row
Static xRow
If xRow <> "" Then
xRow = pRow
.ColorIndex = 10
.Pattern = xlSolid
Thank you,
Nisarga.
