Using Named Cells to Define a Print Range
jdmaybee
I use Excel to import a recievables report from another piece of software. As you can appreciate it is not the same each time I import it.
I have written a macro that does everything I want it to except define a range using a range name I define as Topleft (for say, cell A240) and Bottomright (for say, cell M820)
I cannot seem to find the correct syntax for this since Excel seems to alway want to use finite terms and the range between Topleft and Bottomright can vary each time I import the file.
dan_l
I'm not following: you're just trying to define a range between A240 and M820?
I guess my question is: which of the following best describes what you're trying to do?
A. Define a range based on user provided details
B. Define a range based on criteria within the data
jdmaybee
It's a bit more difficult than that - that's why I named the two ranges I want to use to define the area - one day it will be A240 to M820 - the next it will A320 to M900. I want to be able to define a print range using the Topleft and Bottomright range names.
Nunes
using the .RefersTo property, you can extract a string with the Range inside you named ranges, but it extracts the complete address of the range, like "sheet!$A$1"...
simple string management can get you rid of the "sheet!" part of the string, and the sky is now the limit! :D
something like this:
______________________________
Dim aux_string, new_Topleft, new_Bottomright As String
aux_string = ThisWorkbook.Names("Topleft").RefersTo
'aux_string is now a string with complete address of range "Topleft"
'we should now get rid of the sheet reference in the left part of this
new_Topleft = Right(aux_string, Len(aux_string) - InStr(aux_string, "!"))
'done! new_Topleft is a string with simple cell address of range "Topleft"
aux_string = ThisWorkbook.Names("Bottomright").RefersTo
'aux_string is now a string with complete address of range "Bottomright"
new_Bottomright = Right(aux_string, Len(aux_string) - InStr(aux_string, "!"))
'done! new_Topleft is a string with simple cell address of range "Bottomright"
'now we apply it to the print area
ActiveSheet.PageSetup.PrintArea = new_Topleft & ":" & new_Bottomright
jdmaybee
Wow! Does that ever work!!
As an old Lotus user I could literally write a macro by copying all the key strokes I used and bingo I had a macro.
I had the (what turns out to be very unrealistic) idea I could figure out how to do this on my own!
Just out of curiosity do you know how to name a range without having the RefersToR1C1:="=Sheet3!R8C1" part at the end? I want to be able to select the ActiveCell name a range.
Thanks again
