Using Excel to find Lat and Long from a street address (geocode)
bvanscoy678
After reading Chandoo's posting on "Finding a Zip Code" with the new formulas in Excel 2013, that got me thinking. I have a list of several hundred addresses that I would like to find the lat and long for each one. Can this be done?
Thanks,
Brent
I was able to find a website called Mapcite.com. Not sure if this is what I am looking for, but I'll give it a test. Thanks
Hi, bvanscoy678!
If you haven't performed yet the search herein, try going to the topmost right zone of this page (Custom Search), type the keywords used in Tags field when creating the topic or other proper words and press Search button. You'd retrieve many links from this website, like the following one(s) -if any posted below-, maybe you find useful information and even the solution. If not please advise so as people who read it could get back to you as soon as possible.
http://chandoo.org/forums/topic/find-latitude-and-longitude-of-any-address-using-google-map-api-and-vba
Regards!
SirJB7,
Yes, you are correct. I should have searched first. The idea popped in my head as I was reading Chandoo's post. Thank you for the link.
Brent
Hi, bvanscoy678!
Glad to help. Thanks for your kind words and welcome back whenever needed or wanted.
And of course, just advise if any issue.
Regards!
I'd suggest reading this:
http://policeanalyst.com/using-the-google-geocoding-api-in-excel/
Here are two UDFs one for Latitude and one for Lonitude. You can use them in a macro or as a formula
i.e. lat(A1) will return the latitude of the place/postal code in A1
[pre]
'finds the longitude of a postcode
'max 650 queries per 24 hours
Function lon(z_t As String)
Dim sURL As String
Dim BodyTxt As String
Dim apan As String, lo_g As String
Dim oXH As Object
'create web url
sURL = "http://maps.googleapis.com/maps/api/geocode/xml?address="
sURL = sURL & Replace(z_t, " ", "+") & ",+" & _
"&sensor=false"
' browse url
Set oXH = CreateObject("msxml2.xmlhttp")
With oXH
.Open "get", sURL, False
.Send
BodyTxt = .responseText
apan = Application.WorksheetFunction.Trim(BodyTxt)
'Longitude
apan = Right(apan, Len(apan) - InStr(1, apan, "<lng>") - 4)
lo_g = Left(apan, InStr(1, apan, "</lng>") - 1)
lon = lo_g
End Function
'finds the latitude of a postcode
Function lat(z_t As String)
Dim sURL As String
Dim apan As String, la_t As String
Dim oXH As Object
'create web url
"&sensor=false"
' browse url
With oXH
.Send
'Latitude
apan = Right(apan, Len(apan) - InStr(1, apan, "<lat>") - 4)
la_t = Left(apan, InStr(1, apan, "</lat>") - 1)
lat = la_t
End Function
[/pre]
How timely
Doug over at http://newtonexcelbach.wordpress.com posted this today:
http://newtonexcelbach.wordpress.com/2013/04/19/geodesix/
In Excel 2013 this can be achieved with a combination of:
A1=WEBSERVICE("http://maps.googleapis.com/maps/api/geocode/xml?address=POSTCODEHERE+,+&sensor=false") > replace POSTCODEHERE with your post code / zip
To extract the latitude
B1=FILTERXML(A1,"//result/geometry/location/lat")
To extract to longitude
B1=FILTERXML(A1,"//result/geometry/location/lng")
Some of the nice(r) features of Excel 2013
Cheers
G
Cheers
G
Request you to help me with FILTERXML data.
I have mapped one RSS to an excel file. While all other data comes clean in various cells, one cell gets a piece of HTML/XML. It looks like this -
table border="0" cellspacing="4" cellpadding="2"> <tr> <td style='background-color:#CADDEC;FONT-FAMILY: Verdana,Arial,San-serif; FONT-SIZE: 8pt; FONT-WEIGHT: bold; Color:#012540;'><b>AUM Month </b></td> <td style='FONT-FAMILY: Verdana,Arial,San-serif; FONT-SIZE: 8pt; Color:#012540;'> Jul-2014 </td></tr><tr> <td style='background-color:#CADDEC;FONT-FAMILY: Verdana,Arial,San-serif; FONT-SIZE: 8pt; FONT-WEIGHT: bold; Color:#012540;'><b>Average AUM Excluding Fund of Funds</b></td> <td style='FONT-FAMILY: Verdana,Arial,San-serif; FONT-SIZE: 8pt; Color:#012540;'> 2250809.98 </td></tr><tr> <td style='background-color:#CADDEC;FONT-FAMILY: Verdana,Arial,San-serif; FONT-SIZE: 8pt; FONT-WEIGHT: bold; Color:#012540;'><b>Average AUM Fund of Funds </b></td> <td style='FONT-FAMILY: Verdana,Arial,San-serif; FONT-SIZE: 8pt; Color:#012540;'> 10715.85 </td></tr></table>
Now, I need your help with the following questions?
1- Does this qualify as XML for the FILTERXML to work?
2- If yes, please let me know the formula /xpath to filter
AUM Month, Average AUM Excluding Fund of Funds and Average AUM Fund of Fund.
3- If this is not possible by filterxml, do you have any other solution?
