Derick Pitcher
Hello All,
This is my first post but I've been all over Chandoo.org for quite some time and the information here has helped me tremendously. I'm also using some code from Chandoo.org in my project.
I am relatively new to VBA and pretty good at Excel formulas (need to learn a lot more though). I need to take a VBA class.....
This issue has been a major pain for me. I'm so close to completion but this is keeping me back.
I built a payroll project and use a Userform (EmpEnt) for employee entries. I have the following controls in EmpEnt:
Here's a link to the file on Google Drive, no log-in necessary.
https://drive.google.com/file/d/13cQs0WvVz2m8ezPeEkLTGhviiXrGe2xH/view?usp=sharing
And now, the code where I'm having the problems.....
Code for EmpEnt Userform. Procedures with problems in red text.
- Reg1 - DTPicker - User choses a date ***Posted To Sheet***
- Textbox1 - TextBox - Month value is displayed from Reg1. This is the name of the month payroll sheet posting all entered data in EmpEnt.
- Reg2 - ComboBox - user selects an Employee's name ***Posted To Sheet***
- Reg3 - TextBox - Hourly Pay Rate is Automatically filled in via Vlookup using Reg2 Change ***Not Posted To Sheet***
- Reg4 - TextBox - User enters employee's hours for the week worked ***Posted To Sheet***
- Reg5 - TextBox - User enters employee's hours for Public Holiday & Day Off worked ***Posted To Sheet***
- Reg6 - TextBox - User enters employee's Insurance Deductions ***Posted To Sheet***
- Reg7 - TextBox - User enters employee's Miscellaneous Deductions ***Posted To Sheet***
- CmdAdd - Button - Sends the entered data in Reg1 through Reg7 to the sheet listed in TextBox1 ***Need Help*** Sends all but Reg3
- CmdClr - Button - Clears the entered data ***Need Help***
- CmdExit - Button - Copies all data with date in Reg1 from sheet in TextBox1 to Payroll sheet for use in word Mail Merge Pay Slips then closes the userform EmpEnt
Private Sub CmdAdd_Click() 'not passing Reg3 to worksheet
'Button To Add Reg1 through Reg7 Values to Worksheet (sht)
Dim sht As Worksheet
'Dim pydt As Worksheet
Dim nextrow As Range
Dim i As Integer, c As Integer
'turn error handling on
On Error GoTo myerror
'set the variable for the sheets
Set sht = ThisWorkbook.Worksheets(TextBox1.Value)
'Set pydt = ThisWorkbook.Worksheets(TextBox1.Value)
'unprotect sheet posting to
sht.Unprotect Password:=""
'check for Employee name
If Trim(Me.Reg2.Value) = "" Then
Me.Reg2.SetFocus
MsgBox "Please select an Employee", 48, "Entry Required"
'next blank row
Set nextrow = sht.Cells(sht.Rows.Count, 2).End(xlUp).Offset(1, 0)
c = 0
For i = 1 To 7
With Me.Controls("Reg" & i)
'add the data to the selected worksheet
nextrow.Offset(, c).Value = .Value
'clear the values in the userform
If i > 1 Then .Value = ""
'next column
c = c + 1
'move to column
If c = 5 Then c = c + 4
'protect sheet posting to
sht.Protect Password:=""
myerror:
If Err <> 0 Then
'something went wrong
MsgBox (Error(Err)), 48, "Error"
'communicate the results
MsgBox "The values have been sent to the " & sht.Name & " sheet", 64, "Record Saved"
Me.Reg1.SetFocus
Private Sub CmdClr_Click() 'Compile Error: Variable not defined
For Each ctrl In Me.Controls
Select Case TypeName(ctrl)
Case "TextBox"
ctrl.Text = ""
Case "ComboBox"
ctrl.ListIndex = -1
End Select
Private Sub CmdExit_Click()
Dim ws As Worksheet
Dim pyrlsh As Worksheet
Set ws = ThisWorkbook.Worksheets(EmpEnt.TextBox1.Value)
Set pyrlsh = ThisWorkbook.Worksheets("PayRoll")
ws.Unprotect Password:=""
pyrlsh.Unprotect Password:=""
'copy date and month to payroll sheet
[PayDate] = Reg1.Value
[PostSht] = TextBox1.Value
'macro to clear the sheet of all data and border formatting
Call ClrPyRl
ws.Protect Password:=""
pyrlsh.Protect Password:=""
ThisWorkbook.Worksheets("Interface").Activate
Unload Me
Private Sub CmdExitToNIS_Click() 'Exits and activates NIS Worksheet
Dim ws As Worksheet
Call ClrPyRl
ThisWorkbook.Worksheets("NI 184").Activate
Unload Me
Private Sub Reg1_Change()
Dim DT As Date
DT = DateValue(Me.Reg1.Value)
TextBox1.Value = Format(DT - 4, "mmmm")
Private Sub Reg2_Change() 'VLookup procedure - need better error checking
'Dim EmpName As String
'Dim empinf As Worksheet
'EmpName = Me.Reg2.Value
'Set empinf = ThisWorkbook.Worksheets("Employee Information")
'empinf.Unprotect Password:=""
'On Error Resume Next
Reg3.Value = Application.VLookup(Reg2.Value, Sheets("Employee Information").Range("B3:I50"), 8, False)
'On Error GoTo 0
'If Ret <> "" Then MsgBox Ret
'empinf.Protect Password:=""
Private Sub TextBox1_Change()
'EmpEnt.TextBox1.Value.Select
Me.MonthView1.Value = Me.Reg1.Value
Me.Reg1.Value = Date
