Use UDF within Index and Match
Mofi454
I have a UDF that performs a count function based on background colour. I wish to use the UDF within an Index and Match function.
What I would like to do is for the Index function to use my UDF to sum the different colours within my sheet.
So instead of it performing say
Index(b7:T30,(match(V7,A7:A30,0),Match(W5,B5:T5,0)) and returning the value of the cell
I would like it to perform the following
Index(GetColourCount(b7:T30,V6),(match(V7,A7:A30,0),Match(W5,B5:T5,0)) and return the count of the colours
Fluff13
Why not change the UDF to
Function GetColourCount(CountRange As Range, CountColor As Range, Dept As String, Yr As String) As Long
    Dim CountColourValue As Integer
    Dim TotalCount As Integer
    CountColourValue = CountColor.Interior.ColorIndex
    Set rcell = CountRange
    For Each rcell In CountRange
      If Cells(rcell.Row, 1) = Dept And Cells(5, rcell.Column) = Yr Then
         If rcell.Interior.ColorIndex = CountColourValue Then
           TotalCount = TotalCount + 1
    Next rcell
    GetColourCount = TotalCount
End Function
Used like
=GetColourCount($B$7:$T$30,$V$6,$V7,W$5)
Mofi454
Thank you for your help. That works perfectly.
Is there a way for me to get the UDF to recalculate everytime I change the background colour within the range B7:T30 without using Application Volatile?
Fluff13
You could use a Worksheet_SelectionChange event to recalculate the sheet, but I think that's about it.
Excel does not recognise a cell colour being changed.
Mofi454
So I tried the following, but it doesn't work
    If Not Intersect(Target, Target.Worksheet.Range("$B$7:$T$30")) Is Nothing Then
            Application.CalculateFull
Fluff13
It won't work on a change event, it needs to be a SelectionChange like
   If Not Intersect(Target, Range("B7:T30")) Is Nothing Then
      Me.Calculate
