Update Cells in Range Based on Condition, within same worksheet
gvs
Greetings,
I would appreciate your help with VBA Code for the following requirement
- This is all within the same worksheet
- If value in cell D2 = 1, then Copy value from Cell B2 and Paste into Cell C2
- If value in cell D2 = 0; skip row and do not update cells C2
- Go through the entire range until all rows are checked and cells in C are updates as needed
- Need to exclude header row 1 and subtotal row at the end of the range
Expense (Col A)OriginalTax (Col B)NewTax (Col C)Variance (Col D)
Exp1
5.74​
5.74​
0​
Exp2
4.56​
2.1​
1​
Exp3
12.34​
12.43​
1​
Exp4
10​
9​
1​
Exp5
9​
9​
0​
Exp6
8​
8​
0​
Exp7
7​
7​
0​
Exp8
4​
3​
1​
Exp9
3​
2​
1​
Exp10
5​
5​
0​
SUBTOTAL
68.64​
63.27​
gvs
gvs
Please, next time upload a sample Excel-file.
Here, a sample code.
Hello vletm,
Thank you for the reply, but unable to see the sample code in your xlsb workbook. Attached is my sample workbook; I would appreciate if you can add the code in it.
Kind Regards,
gvs
gvs
nevermind...found it and it works!!! thank you so very much!!!
Appreciate your help.
Happy New Year!!
gvs
