A11 Mighty
Hello -
I ve searched and didn't come across a solution that will help with my need. Looking for some assistance with my request:
Request #1
Need to unlock 1 specific cell in a row based on a specific value selected through a dropdown in the same row:
If B12 = OPEN, Unlock F12
NOTE: If the value of B12 is different than "Open" F12 should be locked
The code need to repeat for each row: If A13 = Open, F13.
Request #2
Need to unlock specific cells in a row based on a specific value selected in the same row, and if it's not too match asking change the color of the cell from current color to something that will indicate they are active or unlocked.
If F12 = 1, Unlock G12
If F12 = 2, Unlock both G12 & H12
If F12 = 3, Unlock G12 & H12 & I12
If F12 = 4, Unlock G12 & H12 & I12 & J12
If F12 = 5, Unlock G12 & H12 & I12 & J12 & K12
If F12 = Max, Unlock G12 & H12 & I12 & J12 & K12 & L12
The code need to repeat for each row: If F13= 1 then 2 .....
I've attached a sample sheet with current project layout I am working on.
Any help will be much appreciated.
Thank you,
A11 Mighty
Request #1
Request #2
Thank you,
A11 Mighty
