Unique Values in drop down
rupal1234
NAMES
AANCHAL
RUPAL
RAHUL
RAM
SHYAM
RUPAL
RAHUL
AANCHAL
Here i want unique values in drop down like non repeated values in dropdown.
For eg. if AANCHAL is coming two times then it would show only one time in my dropdown
rahulshewale1
Hi @rupal1234 ,
You can do many Way ?
Method 1 :
=K4 Copy Down formula
=IFERROR(INDEX($A$4:$A$12,MATCH(0,COUNTIFS($K$4:K4,$A$4:$A$12),0)),"")
Then Use offset Formula for Dynamic range for Unique Names
Go To Name Manager > New > Given Name > Copy Below Formula > ok > Close
=OFFSET(Sheet1!$K$5,,,MATCH("",Sheet1!$K$5:$K$13,0)-1,)
Then Go to Data validation > Allow Select List > Press F3 >Source :=Select Name Mangar Name > Ok
Method 2 : Using Power Query
1) Convert Input Names Range To Table ( Ctrl + T )
2) Go to Power Query Tab > From Table Or Range Select > Power Query Window Will Appeared > Home Tab > Remove Rows > Remove Duplicate > Close & Load
3)Unique Name only visible only
Method 3 : Using Unique Function ( Only For Office 365 or Office 2019)
=UNIQUE(A5:A12)
Regard
Rahul shewale
