Unique values from an unsorted column meeting a certain criteria
AK
Hello
I need to derive sorted unique values from column. For the purpose I use the following formula from cell A3 below onwards entered as an array formula:
INDEX(List, MATCH(0, IF(MAX(NOT(COUNTIF(A$2:$A2, List))*(COUNTIF(List, ">"&List)+1))=(COUNTIF(List, ">"&List)+1), 0, 1), 0))
This formula gives me the desired results.
However, now i want to derive sorted unique values which contain a string e.g. ABC
If the column values are:
ABC-001
DEF-001
GHI-003
ABC-001
ABC-002
GHI-008
I want to derive only the values:
ABC-001
ABC-002
Could anyone please help?
Hui
Staff member
AK
In Excel 2003 use
Filter, Dont Set any criteria, then
Advanced Filter and set the Criteria Range to ="=ABC*"
Set Copy to Another Location and Unique Records only
AK
Hello Hui
I do not want any manual step. I want to use formulae so that any change/update to the List automatically updates the derived list.
Clarity
AK
If you use Chandoo's sort blog and then limit it to lines starting with "ABC" this will hopefully acheive what you are after.
http://chandoo.org/wp/2008/10/22/sorting-text-in-excel-using-formulas/
Myles
