I wanted to explore excel feature. Recently I have started writing UDF
(User Defined Functions) in excel which will help in my day to day life. I stuck in some problem Can you please help me on below things
1 . In my workbook I have many sheets. In each sheet I have used same UDF
functions which will parse some range of cells and extract relevant data. Issue is
UDF function takes active sheet data (if I open workbook or press
Clt+Alt+Shift+f9). Logically it is true but I want UDF function operates on
caller worksheet data (i.e If it is called in sheet1, it should take all data from Sheet1, but currently if I press Clt+Alt+Shift+f9 in sheet1, Sheet1, Sheet2 all will have as per sheet1 data). Please let me know if you have any suggestion/solution.
2. I have three column A,B,C and in next sheet I will use C' column as A' +
B' = C', where A' = A+B) and so on. Since sheet names will have fixed pattern
I wrote a UDF which will fetch this but it shows Circular reference error. Is
any workaround is there
