Chirag R Raval
Dear All,
Various types of macros on the web found that use various approach to remove unused part from the sheet.
Finally that code seems reliable , which only trap cells contain literal text or numbers, & not Formatting or formula .
I found very helpful forever 2 Macros from the web that remove extra rows & columns beyond actual used range and reset the last cell ,both macros, used range find method.
Macro 1
Without Xlpart Or Xlwhole
Above don't use Xlpart or XlWhole in find method...
Macro 2
with use of XlWhole only in find method..
(1) it is effective to not to use Xlpart or XlWhole in Macro1?
(2) what is key roll of XlWhole & XlPart in find method?
(3) what is the reason Why not to use XLPart in Macro2?
Though , Just 1 minus point of above 2 codes that just simple single literal space remains in cell, that counted as used cell. If, this limitation can be remove from this codes, then can be most reliable to reset used range.
can any one guide about it? it will be appreciated forever...
Chirag Raval
Macro 1
Sub DeleteUnusedFormats()
Dim lLastRow As Long, lLastColumn As Long
Dim lRealLastRow As Long, lRealLastColumn As Long
With Range("A1").SpecialCells(xlCellTypeLastCell)
lLastRow = .Row
lLastColumn = .Column
lRealLastRow = Cells.Find("*", Range("A1"), xlFormulas,, xlByRows, xlPrevious).Row
lRealLastColumn = Cells.Find("*", Range("A1"), xlFormulas,, _
xlByColumns, xlPrevious).Column
If lRealLastRow < lLastRow Then
Range(Cells(lRealLastRow + 1, 1), Cells(lLastRow, 1)).EntireRow.Delete
If lRealLastColumn < lLastColumn Then
Range(Cells(1, lRealLastColumn + 1), _
Cells(1, lLastColumn)).EntireColumn.Delete
ActiveSheet.UsedRange 'Resets LastCell
Macro 2
'Note: This code may not work correctly if the worksheet contains merged cells. To check 'your worksheet, you can run the TestForMergedCells code.
Sub DeleteUnused()
Dim myLastRow As Long
Dim myLastCol As Long
Dim wks As Worksheet
Dim dummyRng As Range
For Each wks In ActiveWorkbook.Worksheets
With wks
myLastRow = 0
myLastCol = 0
Set dummyRng = .UsedRange
myLastRow = _
.Cells.Find("*", after:=.Cells(1), _
LookIn:=xlFormulas, lookat:=xlWhole, _
searchdirection:=xlPrevious, _
searchorder:=xlByRows).Row
myLastCol = _
searchorder:=xlByColumns).Column
On Error GoTo 0
If myLastRow * myLastCol = 0 Then
.Columns.Delete
.Range(.Cells(myLastRow + 1, 1), _
.Cells(.Rows.Count, 1)).EntireRow.Delete
.Range(.Cells(1, myLastCol + 1), _
.Cells(1, .Columns.Count)).EntireColumn.Delete
Next wks
Sub TestForMergedCells()
Dim AnyMerged As Variant
AnyMerged = ActiveSheet.UsedRange.MergeCells
If AnyMerged = False Then
MsgBox "no merged"
ElseIf AnyMerged = True Then
MsgBox "all merged"
ElseIf IsNull(AnyMerged) Then
MsgBox "mixture"
MsgBox "never gets here--only 3 options"
Chirag Raval
