textjoin help
r121a947
I am trying to create a textjoin macro that will recombine sorted words from a range of columns. The textjoin statement works in a single cell, but when I try to put it in a macro, I get a "syntax error" statement.
The macro code is:
Public Sub rejoinJ()
Dim i As Long
Dim lRow As Long
lRow = Cells(Rows.Count, 1).End(xlUp).Row
Dim curRow As Long
curRow = 1
For i = curRow To lRow
TEXTJOIN(" ", TRUE, "N" & curRow   & ":BA" & curRow)
' MsgBox curRow
curRow = curRow + 1
Thanks. Any help is greatly appreciated.
Hi r121a947,
try this code, assuming you want to write the merged text in column B
    Dim i As Long
    Dim lRow As Long
    Dim JoinedText As String
    For i = 1 To lRow
        JoinedText = WorksheetFunction.TextJoin(" ", True, Range("N" & i & ":BA" & i))
        Range("B" & i).Value = JoinedText '====> adapt the destination colum as needed
