Subtract From two Columns and Total the difference
Azad
I have two columns with values.i.e I would like to subtract A from B with a condition.
See sample formula I am using below
H K
10 15
5 3
28 30
={IF(((K16:K4398)-(H16:H4398))>0,SUM(K16-H4398),"X"}
However I am only getting X.I know the answer should be a numeric value.
Any help would be appreciated
Azad
If it is a normal formula then the format should be
=IF( Sum(K16:K4398)- Sum(H16:H4398) >0, SUM(K16-H4398), "X")
But the last Sum "SUM(K16-H4398)" is a strange format ?
Maybe it should be
SUM(K16:K4398) or SUM(H16:H4398) or SUM(K16:H4398)
The only time you see {} brackets is in Array Formula
and the user doesn't put those in Excel will do it for you
If I understand correctly you want to sum all the differences when the value in column K is bigger than in H?
The easiest way is probably to use a helper column and first calculate the differences in column L with max(K2-H2,0) and then sum that.
Azad
This will do what TessaES suggested without a helper column
=+SUMPRODUCT(1*((H16:H4398)-(K16:K4398)>0),((H16:H4398)-(K16:K4398)))
