Split small letters from a text string
AAP
I would like to separate small letters from a text string.
Ex:
Text String: ED276Ubiipx
Result Needed: biipx
I have attached a sample file.
  • Sample File.xlsx
I came up with this Power Query solution
let
    #"Duplicated Column" = Table.DuplicateColumn(Source, "TEXT", "TEXT - Copy"),
    #"Split Column by Character Transition" = Table.SplitColumn(#"Duplicated Column", "TEXT - Copy", Splitter.SplitTextByCharacterTransition({"A".."Z"}, {"a".."z"}), {"TEXT - Copy.1", "TEXT - Copy.2"}),
    #"Split Column by Character Transition1" = Table.SplitColumn(#"Split Column by Character Transition", "TEXT - Copy.1", Splitter.SplitTextByCharacterTransition({"0".."9"}, (c) => not List.Contains({"0".."9"}, c)), {"TEXT - Copy.1.1", "TEXT - Copy.1.2"}),
    #"Added Conditional Column" = Table.AddColumn(#"Split Column by Character Transition1", "Extract LowerCase", each if [#"TEXT - Copy.2"] = null then [#"TEXT - Copy.1.2"] else [#"TEXT - Copy.2"]),
    #"Removed Columns" = Table.RemoveColumns(#"Added Conditional Column",{"TEXT - Copy.1.1", "TEXT - Copy.1.2", "TEXT - Copy.2"})
in
    #"Removed Columns"
Not sure it would cover all cases though.
EDIT: Slightly improved code could be (used in attached file)
let
    #"Split Column by Character Transition" = Table.SplitColumn(#"Duplicated Column", "TEXT - Copy", Splitter.SplitTextByCharacterTransition({"0".."9"}, (c) => not List.Contains({"0".."9"}, c)), {"TEXT - Copy.1", "TEXT - Copy.2"}),
    #"Added Prefix" = Table.TransformColumns(#"Split Column by Character Transition", {{"TEXT - Copy.2", each "A" & _, type text}}),
    #"Split Column by Character Transition1" = Table.SplitColumn(#"Added Prefix", "TEXT - Copy.2", Splitter.SplitTextByCharacterTransition({"A".."Z"}, {"a".."z"}), {"TEXT - Copy.2.1", "TEXT - Copy.2.2"}),
    #"Removed Columns" = Table.RemoveColumns(#"Split Column by Character Transition1",{"TEXT - Copy.1", "TEXT - Copy.2.1"}),
    #"Renamed Columns" = Table.RenameColumns(#"Removed Columns",{{"TEXT - Copy.2.2", "Extract"}})
in
    #"Renamed Columns"
  • ExtractLowerCase - Sample File.xlsx
