Sparklines Using Non-Contiguous Range
jdppep
Is it possible to create a sparkline using a non-contiguous range? All data is located within the same row; however, evenly spaced, two cells apart. Would a named range work and if so, how would I name a range the sparkline would recognize?
My data is located: =Dashboard!E15,G15,I15,K15,M15,O15,Q15,S15
I am trying to avoid dummy rows/columns.
Thank you!
Give the non-continuous cells a Range name, such as "MyRange", and you can then have the sparkline refer to that named range. :)
Specifically, how should I enter the range information?
If I simply select the individual cells:
=Dashboard!$E$15,Dashboard!$G$15,Dashboard!$I$15,Dashboard!$K$15,Dashboard!$M$15,Dashboard!$O$15,Dashboard!$Q$15,Dashboard!$S$15
and name them as a range "Sparkline"
I receive the following error when I go to Create Sparklines and enter the Data Range: Sparkline
"The reference for the location or data range is not valid"
Of note, there are empty cells in this range.
Put an "=" sign in front of the range. In the dialogue, it would be:
=Sparkline
On the Sparkline design ribbon, Edit Data, you can choose how the sparkline handles empty cells.
I was placing the sparkline in a merged cell, which did not work. After defining the sparkline, I was able to merge the cells.
Thanks!
