Sorting date, and then enter values using sorted date from two tables
hello all,
I need a help, as I have two different tables with multiple values in it. What I want is to combine both table[date] to one and then sort the date, then on the other sheet I need to lookup for the sorted date. and lookup for the other values. I'm uploading a Picture of two tables.
I tried Sorting date using
=INDEX($L$23:$L$70,MATCH(ROWS($L$23:L28),COUNTIF($L$23:$L$70,"<="&$L$23:$L$70),0))
but in result on empty cells I get error of "#N/A", please help me to remove that too
This pic is of result as I want but It consist of errors.
bosco_yip
Please check the attached file
1] In "Date" column, M19 array formula (confirmed enter with Ctrl+Shift+Enter) copied down :
=IFERROR(SMALL(IF(CHOOSE({1,2},Table1[VOU_DATE],Table2[VOU_DATE])>0,CHOOSE({1,2},Table1[VOU_DATE],Table2[VOU_DATE])),ROWS($1:1)),"")
2] In "Vouno" column, N19 formula copied down :
=IF($M16="","",IFERROR(INDEX(Table1[VOUNO],MATCH($M16,Table1[VOU_DATE],0)),IFERROR(INDEX(Table2[VOUNO],MATCH($M16,Table2[VOU_DATE],0)),"")))
3] In "Narr1" column, O19 formula copied down :
=IF($M16="","",IFERROR(INDEX(Table1[NARR1],MATCH($M16,Table1[VOU_DATE],0)),IFERROR(INDEX(Table2[NARR1],MATCH($M16,Table2[VOU_DATE],0)),"")))
Bosco
bosco_yip
@bosco_yip I need one more help, regarding search box in excel, value must change according to the input value in the box
1] Try to enter "A" or "AM" in the Search Box of cell D3 for testing
2] 2 helper columns are added in Col N and Col O being for the Lookup range of the Validation list
3] See attached file, and check the formula used in the D4 Validation list
Bosco
Bosco
sir,
i need some litttle more help in this case:
as before your formula, I was using
=IFERROR(INDEX($J$23:$J$66,MATCH(ROWS($J$23:J26),COUNTIF($J$23:$J$66,"<="&$J$23:$J$66),0)),"")
I was using this formula,
I'm getting error in your formula and mine formula too, as if there are more entries with same date, I cannot sort them or those cell become empty
Please find the attached file, I made some changes in old file.. i need that update
Please help me
I haven't attached the formula, I need to attach please check the jpg file what error I,m getting.
As there are multiple same dates in the table, but only one is visible on the result panel, I need all of them to be visible
Please see it's a request
Can y
Why not sort by VOUNO instead?
Sir can you help me for this thing, like first to be sorted by vou no, then again it must be sorted by dates.. as it must be easy
Coz the 30/06/2018 is only posted quaterly in the whole sheet, now the next date will be 30/09/2018
And rest of the dates will be regular
Sir,
I cannot use this formula for date
even after I use CTRL + SHIFT + ENTER
No result is there only blank
Uploading the screenshot
A5:H25 is TABLE [VOU_LED}
J5:Q19 is TABLE [ VOU_MCODE]
