Solution required please
Status
Not open for further replies.
HafNah1951
Hello see attached,
Column N and O requires formula
N6 should give 6.5 as result since hours worked should be fully considered on public holidays
N7 should give 6.5+3.5 as result. The 3.5 is obtained by taking into consideration that in a week there was one public holiday and 4 normal days. The employee should have worked (9*4)=36 but has worked ((9*3)+12.5)=39.5.
N8 should give only 0.5 as result as the overtime relates to another employee.
Also Note, overtime eligible per employee in a week with no public holidays is total overtime hours worked minus 5 hours. (45 statutory hours are considered before becoming eligible for overtime)
Please help to edit formula in column N and insert a formula in column O which should generate the total overtime hours per employee per week which the employee will be paid.
  • Overtime Calculation.xlsx
HafNah1951
As written - please do not duplicate Your thread.
This 2nd time duplicated thread is also closed.
Status
