So you only ever want one row in a table? If not, what decides whether a date is an 'old date' or not?and please clear the tables from old dates
Later today I'll add 2 more tables and buttons. I'll leave you to do the repetitive work and add any more that you need.it looks great. how can i add more tables? I need them at least 25
which rows in the code should I edit so I can add more tables?
ButtonNames = Array("Button1", "Button2", "Button3", "Button4")
TableNames = Array("durations1", "durations2", "durations3", "durations4")
it looks amazing. send me a contact to send you a present
if you have time for macro (ClearTables) to clear all the tables and reset all the buttons to Start. I would be grateful. you have a little present from meSee attached. You should be doing this then you'll know how to do it. I'm not going to be here all the time to update your project.
There's also a macro (ClearTables) to clear all the tables and reset all the buttons to Start.
It's there already!if you have time for macro (ClearTables) to clear all the tables and reset all the buttons to Start.
