A11 Mighty
Hello - Looking for some assistance to see if there are ways to help simplify and speed the Macros listed below.
This code was developed by a previous colleague.
Attached file for reference.
Also, remove the Unprotect and Protect Active sheet as it's not required.
Add lines command button
Delete Line
Private Sub Assembly_BOM_Add_Lines_Click()
ActiveSheet.Unprotect
'Find the end of the BOM section
Dim r As Integer
Dim EndRow As Integer
For r = 12 To 112
If Sheets("GM Analysis").Range("A" & r).Value = "Total value for of Materials" Then
EndRow = r - 2
GoTo A
Next r
MsgBox ("The sheet already has the maximum number of line items.")
GoTo Z
A: 'Find where to insert rows and check to make sure it is in the BOM section
Dim InsertRow As Integer
InsertRow = ActiveCell.Row
If InsertRow < 12 Or InsertRow > EndRow Then
MsgBox ("Where do you want to insert the row? Please select a cell in the Bill of Materials section and click the button again.")
GoTo Z
'Ask how many rows to insert and check to make sure that it will not cause the BOM section to exceed 100 line items
Dim MaxRows As Integer
MaxRows = 100 - EndRow + 11
Dim NumberRows As Variant
B: NumberRows = InputBox("How many rows would you like to insert? You can insert up to " & MaxRows & ".")
If NumberRows = Cancel Then GoTo Z
If Not NumberRows <= MaxRows Then
MsgBox ("You have specified too many lines.")
GoTo B
'Copy row from Extra Lines tab and insert it into the BOM section
Dim n As Integer
For n = 1 To NumberRows
Sheets("Extra Lines").Rows(2).Copy
Sheets("GM Analysis").Activate
ActiveSheet.Rows(InsertRow).Select
Selection.Insert Shift:=xlDown
Next n
Z:
ActiveSheet.Protect
Delete Line
Private Sub Assembly_BOM_Delete_Line_Click()
Dim r As Integer
For r = 12 To 112
If Sheets("GM Analysis").Range("A" & r).Value = "Total value for Bill of Materials" Then
EndRow = r - 2
GoTo A
'MsgBox (Selection.Rows.Count)
Next r
MsgBox ("Error: Cannot find the end of the BOM section.")
GoTo Z
A: 'Loop thru selections in BOM section and ask user if they want to delete each one
Dim CurrentRow As Integer
Dim LineItem As Integer
Dim UserResponse As Variant
For CurrentRow = EndRow To 12 Step -1
If Not Intersect(Rows(CurrentRow), Selection) Is Nothing Then
LineItem = Sheets("GM Analysis").Range("A" & CurrentRow)
UserResponse = MsgBox("You are about to delete line item number " & LineItem & ". You will not be able to undo this action. Do you want to continue?", vbYesNoCancel)
If UserResponse = vbCancel Then GoTo Z
If UserResponse = vbNo Then GoTo B
ActiveSheet.Rows(CurrentRow).Delete Shift:=xlUp
B: Next CurrentRow
Z:
ActiveSheet.Protect
