Simple copy macro not working
Busymanjohn
Hi, I have a simple copy / paste macro recorded ( as below ), but I keep getting a runtime 1004 error and when I look for an explanation into the error I see that this error is common with password protected files .... i've removed the password and i still get the error ,, i'm not very good with vba so any suggestions would be appreciated.
Sub Copyone()
' Copyone Macro
ActiveWindow.LargeScroll Down:=1
Range("B2:AF34").Select
Selection.Copy
Selection.CopyPicture Appearance:=xlPrinter, Format:=xlPicture
Sheets("Ball Scores").Select
Range("B3").Select
ActiveSheet.Paste
ActiveSheet.Shapes.Range(Array("Picture 3")).Select
Range("A2").Select
You may be getting an error as Picture 3 may already exist
Try changing it to Picture 4 and rerun
Try replacing all the above code with:
  Range("B2:AF34").CopyPicture Appearance:=xlPrinter, Format:=xlPicture
  Range("B3").Select
  ActiveSheet.Paste
  Range("B3").Select
  ActiveSheet.Paste
Hi Hui, still not working .... doesn't seem to like the Sheets("Ball Scores").Select line
Can you post the file as it works on a dummy setup here
Hi Hui, sorry I haven't replied sooner, managed to get your solution to work, saved and closed workbook, re-opened and it worked, no idea why, but at least it works now, Thanks for your help :)
