Short gig - Need help to combine 2 live trackers
SekharS
I am looking to combine 2 'live' spreadsheet trackers into one.
Example as attached: Test_A.xlsx & Test_B.xlsx , are maintained by 2 separate teams.
My aim is create a mirrored data from these 2 into, another tab of one of these 2 trackers, and then publish it as a HTML report, upon every save. For ex: the mirror tab may reside in Test_A.xlsx.
On the 'mirror' I want data from 1st team appear & after the first blank row (without any data) is encountered) data from 2nd team should appear.
Each row in a spreadsheet denotes a project, which will be deleted & moved to another tab, when completed.
Both spreadsheet files are hosted on SharePoint.
I tried a formula available on web & tweaked to my needs.
See attached 'Combined_Sample.xlsx'.
Here essentially - I am trying to combine data as described above.
While that's technically working; I will be working with 2 separate spreadsheets hosted on SharePoint (as against 2 tabs in this),it is prompting me an input selection for a new file. See 'prompt.png'.
And that's not acceptable for my need, as I want them to work seamlessly, than input something every time data entered/modified.
Hope I was able to convey my need clearly.
Appreciate any questions.
