    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
short cut to jump between two exact duplicate value cells
Discussion in 'Ask an Excel Question' started by Uzzal, May 10, 2018.
  1. Uzzal
    Uzzal Member
    68
    Hi ! I have got huge number of duplicate cells by applying duplicate value formula of conditional formating. now is there any shortcut key to jump exactly to the same duplicate cell of the first one among the all different duplicate cells.
  2. Marc L
    Marc L Excel Ninja
    4,259
    Hi !
    Just use the Excel search inner feature …​
    Uzzal likes this.
  3. NARAYANK991
    NARAYANK991 Excel Ninja
    16,619
    This can be done using VBA.
    Upload your workbook with the data in it , if you want this solution.
  4. Uzzal
    Uzzal Member
    68
  5. Uzzal
    Uzzal Member
    68
    Hi, Thanks for your response , file uploaded, so far I can remember I did it before (slided the selection cursor from the first cell to the other cell of the same pair of data) only using short cut key. is there really no short cut key to that ? I am confused with my weak memory.
    Thanks, you mean the Cntrl+F find option ?
  6. Marc L
    Marc L Excel Ninja
    4,259
    Yes, the Excel inner search feature …​
  7. p45cal
    p45cal Well-Known Member
    1,247
    In the attached two offerings:
    • Sheet GAP Air PP (hyplnk) if you click on a duplicate (after the first duplicate), it will take you to the first occurrence. There's a button to refresh the hyperlinks should things change or move about.
    • Sheet GAP Air PP (dblclk) If you double-click on a duplicate in column R, it will take you to the first of them. No updating required.
Share This Page
