Separate Numbers by Color
deciog
Gentlemen, good morning.
Only by Formulas, Excel 2016 and 365
I need to separate the numbers by color, according to the model.
Thank you in advance
Decio
  • Separate Numbers by Color.xlsm
As per the file, look like you can use Name range with GETCELL function to create a helper criteria in L3:L8 for the cell color number,
then,
try use the same technique to create a helper cell color number table (Y3:AH12) for the Input table (N3:W12).
After that,
using formula to extract number in referring to the helper table (Y3:AH12), helper criteria (L3:L8) and Input table (N3:W12).
Bosco
Bosco, good morning.
Thank you very much for the tip, it worked very well.
I forward the attached solution
Hugs
Decio
  • Separate Numbers by Color Solução.xlsm
Hugs
Decio
Hi Decio,
You could use this shorter non-array formula instead.
In N14, formula copied across and down :
=IFERROR(AGGREGATE(15,6,$N$3:$W$12/($Y$3:$AH$12=$L3),COLUMN(A1)),"")
Remark : all helper cells can be hidden by using format cell with white color font and white color background.
Bosco
The attached addresses a related problem of how does one colour a randomly generated table.
1. RANDARRAY is used to create the numbered table.
2. SUMIFS is used within a helper range to return the row number corresponding to each element of the array.
3. Conditional formatting and implicit intersection between sheets is used to colour the table.
@deciog
I think this is closer to the problem, as originally specified, in that I have built the lists from the table rather than colouring the table to conform to the list. As I have generated the random distribution of colours using a table of indices, I have then used the helper table to create the lists rather than 'reading' the colours. I have used the LET function to organise the formula. I am not sure whether you have the function yet; otherwise it is a case of reverting to defined names or helper ranges to unpivot the tables.
