Save a sheet in the same workbook but with same print settings.
Jo4x4
I have a sheet with a button on that I use to copy the sheet with a different name in the same workbook. However, the copy doesn't have the same print setup as the original. I know I can press ctrl and save page setup, but this is slow, as there are many copies. Also, someone might forget to do a sheet, and it will then print incorrectly.
Seasons greetings from sunny South Africa!
Jo
Hi everybody. Hope you had a wonderful festive season.
Can somebody please help with some code to copy print settings as well?
Jo
Jo4x4
How about adding the following code to your macro
This was written in Excel 2007
Some of the properties may not be available in earlier versions of Excel
If that is your case run it and when it crashes delete the line with the property that may not be suitable for your version.
[pre]
Sub Copy_Print_Settings()
Dim MyWrkBook As String
Dim NewSht As String
Dim OldSht As String
MyWrkBook = "Copy worksheet.xlsm"  'Change to suit
NewSht = "Sheet2"  'Change to suit
OldSht = "Sheet1"  'Change to suit
Worksheets(NewSht).Select
With ActiveSheet.PageSetup
.LeftHeader = Worksheets(NewSht).PageSetup.LeftHeader
.CenterHeader = Worksheets(OldSht).PageSetup.CenterHeader
.RightHeader = Worksheets(OldSht).PageSetup.RightHeader
.LeftFooter = Worksheets(OldSht).PageSetup.LeftFooter
.CenterFooter = Worksheets(OldSht).PageSetup.CenterFooter
.RightFooter = Worksheets(OldSht).PageSetup.RightFooter
.LeftMargin = Worksheets(OldSht).PageSetup.LeftMargin
.RightMargin = Worksheets(OldSht).PageSetup.RightMargin
.TopMargin = Worksheets(OldSht).PageSetup.TopMargin
.BottomMargin = Worksheets(OldSht).PageSetup.BottomMargin
.HeaderMargin = Worksheets(OldSht).PageSetup.HeaderMargin
.FooterMargin = Worksheets(OldSht).PageSetup.FooterMargin
.PrintHeadings = Worksheets(OldSht).PageSetup.PrintHeadings
.PrintGridlines = Worksheets(OldSht).PageSetup.PrintGridlines
.PrintComments = Worksheets(OldSht).PageSetup.PrintComments
.PrintQuality = Worksheets(OldSht).PageSetup.PrintQuality
.CenterHorizontally = Worksheets(OldSht).PageSetup.CenterHorizontally
.CenterVertically = Worksheets(OldSht).PageSetup.CenterVertically
.Orientation = Worksheets(OldSht).PageSetup.Orientation
.Draft = Worksheets(OldSht).PageSetup.Draft
.PaperSize = Worksheets(OldSht).PageSetup.PaperSize
.FirstPageNumber = Worksheets(OldSht).PageSetup.FirstPageNumber
.Order = Worksheets(OldSht).PageSetup.Order
.BlackAndWhite = Worksheets(OldSht).PageSetup.BlackAndWhite
.Zoom = Worksheets(OldSht).PageSetup.Zoom
.FitToPagesWide = Worksheets(OldSht).PageSetup.FitToPagesWide
.FitToPagesTall = Worksheets(OldSht).PageSetup.FitToPagesTall
.PrintErrors = Worksheets(OldSht).PageSetup.PrintErrors
.OddAndEvenPagesHeaderFooter = Worksheets(OldSht).PageSetup.OddAndEvenPagesHeaderFooter
.DifferentFirstPageHeaderFooter = Worksheets(OldSht).PageSetup.DifferentFirstPageHeaderFooter
.ScaleWithDocHeaderFooter = Worksheets(OldSht).PageSetup.ScaleWithDocHeaderFooter
.AlignMarginsHeaderFooter = Worksheets(OldSht).PageSetup.AlignMarginsHeaderFooter
.EvenPage.LeftHeader.Text = Worksheets(OldSht).PageSetup.EvenPage.LeftHeader.Text
.EvenPage.CenterHeader.Text = Worksheets(OldSht).PageSetup.EvenPage.CenterHeader.Text
.EvenPage.RightHeader.Text = Worksheets(OldSht).PageSetup.EvenPage.RightHeader.Text
.EvenPage.LeftFooter.Text = Worksheets(OldSht).PageSetup.EvenPage.LeftFooter.Text
.EvenPage.CenterFooter.Text = Worksheets(OldSht).PageSetup.EvenPage.CenterFooter.Text
.EvenPage.RightFooter.Text = Worksheets(OldSht).PageSetup.EvenPage.RightFooter.Text
.FirstPage.LeftHeader.Text = Worksheets(OldSht).PageSetup.FirstPage.LeftHeader.Text
.FirstPage.CenterHeader.Text = Worksheets(OldSht).PageSetup.FirstPage.CenterHeader.Text
.FirstPage.RightHeader.Text = Worksheets(OldSht).PageSetup.FirstPage.RightHeader.Text
.FirstPage.LeftFooter.Text = Worksheets(OldSht).PageSetup.FirstPage.LeftFooter.Text
.FirstPage.CenterFooter.Text = Worksheets(OldSht).PageSetup.FirstPage.CenterFooter.Text
.FirstPage.RightFooter.Text = Worksheets(OldSht).PageSetup.FirstPage.RightFooter.Text
[/pre]
Hi Hui,
No, I am way too stupid for this... You helped me with a VLOOKUP that changes my "master sheet" with information stored elsewhere in the workbook. A button then saves this new information as a new sheet, and renames it.
That is where my problem is with your print settings. I don't know how to change the "old sheet" and "new sheet" names.
Here is the code used for the button:
Private Sub Saveandreturn_Click()
Dim sh As Worksheet
With Me
.Parent.Worksheets(.Range("D4").Value).Delete
On Error GoTo 0
Set sh = .Parent.Worksheets.Add(After:=.Parent.Worksheets(.Parent.Worksheets.Count))
sh.Name = .Range("D4").Value
.Cells.Copy sh.Range("A1")
sh.UsedRange.Value = sh.UsedRange.Value
Me.Activate
Thanks again for all your assistance.
Jo
Jo4x4
I have made a few smakll changes to your macro and also changes my previous macro
The changes in your macro extract the old and new sheet names and then calls the new macro to copy the settings
Replace your existing code with this
The 3 changes are commented
[pre]
Dim sh As Worksheet
With Me
OldSht = Me.Name 'This is the existing sheet name
On Error GoTo 0
NewSht = .Range("D4").Value 'This is the New sheet name
Call Copy_Print_Settings(OldSht, NewSht) 'Call subroutine to copy print settings
Me.Activate
[/pre]
and Copy the following to a code module
Sub Copy_Print_Settings(OldSht, NewSht)
.PrintArea = Worksheets(OldSht).PageSetup.PrintArea
.LeftHeader = Worksheets(OldSht).PageSetup.LeftHeader
Works well for me in Excel 2007.
Hi Hui,
I need your help again if you can.
I have uploaded a sample here: http://rapidshare.com/files/440880304/sample.xlsx
On the Electronic score sheet, I will add a list so that the operator can just choose the team, and the driver and nav name will pop up. That is not the problem.
What I need, if possible, is a button to print this sheet, and then save the results to the sheet named "Results".
Not a necessity, but it would be great if the "results" sheet can auto-sort as the team scores are added. There are about 60 teams.
BTW, where in the world are you?
Thanks again
Jo
Jo
Have a look at
http://rapidshare.com/files/441027120/sample.xlsm
Hi Hui,
Thanks for all your help. It works great, except when there is not yet a team in. From the second team it works, but if you clear the values, it then tries to put the first team name at the bottom of the sheet.
Jo
Hi Hui, don't worry about it. I simply put a "fake" team at the top, and then it works fine.
Thanks again
Jo
