Same sl no for exact match row data.
sambit
Unique Serial Number for same data for every row line item.
Criteria =
Vendor Name, Tax Invoice, Date & Amount is equal for every line item.
Pl Note : Amount may be positive or negative.
Revise example file is attached for your kind information
pecoflyer
Your examples are not clear
For instance KPG & CO appears two times with same date / amount/ tax invoice but the expected result is 3 ?
ABC & CO is to be counted 5 times for tax invoice 456 but only appears twice?
sambit
3 & 5 is the unique serial No.
I have assign own sl no for understanding purpose.
My question is if same data is continuing then unique sl No is assigned for every row line item.
Excel Wizard
Maybe try
=IF(COUNTIFS(D$3:D3,D3,F$3:F3,F3,G$3:G3,G3)>1,INDEX(L$3:L3,MATCH(1,(D$3:D3=D3)*(F$3:F3=F3)*(G$3:G3=G3),)),IF(MAX(L$2:L2)>4,"NA",COUNT(1/FREQUENCY(MATCH(D$3:D3&F$3:F3&G$3:G3,D$3:D3&F$3:F3&G$3:G3&{""},),ROW(D$3:D3)-ROW(D$2)))))
Excel Wizard
Try at K3
=IF(SUM(COUNTIFS(B$3:B3,B3,C$3:C3,C3,E$3:E3,E3,F$3:F3,F3,J$3:J3,J3*{1,-1}))>1,INDEX(K$3:K3,MATCH(1,(C$3:C3=C3)*(E$3:E3=E3)*(F$3:F3=F3),)),IF((MAX(K$2:K2)>4)+(COUNTIFS($B$3:$B$20,B3,$C$3:$C$20,C3)<2),"NA",COUNT(1/FREQUENCY(MATCH(C$3:C3&E$3:E3&F$3:F3,C$3:C3&E$3:E3&F$3:F3&{""},),ROW(C$3:C3)-ROW(C$2)))))
sambit
Try at K3
Excel Wizard Sir,
The above formula working fine.
Lot of Thanks.
