Hi
I have placed the following code into a spreadsheet which works perfectly, however I have copied this code and changed the macros being called but the new vba code is still calling the old macro
original code
Dim changed As Range
Set changed = Intersect(Target, Range("E9"))
If Not changed Is Nothing Then
If Target.Value = "" Then
Call UnMergeCells1
Exit Sub
If IsNumeric(Target.Value) Then
If Target.Address = Range("E9").Address Then
Call MergeCells1
Call MergeCells1
With Target
.Select
.ClearContents
Set changed = Nothing
copied code (changes in bold)
Private Sub Worksheet_Change2(ByVal Target As Range)
Set changed = Intersect(Target, Range("E10"))
Call UnMergeCells2
Exit Sub
If Target.Address = Range("E10").Address Then
Call MergeCells2
Call MergeCells2
With Target
.Select
.ClearContents
Although I have changed the name of the code, cell references and the calls for macros the code is still calling for the original macros (numbered 1)
Any help would be greatly appreciated
original code
Call UnMergeCells1
Exit Sub
Call MergeCells1
Call MergeCells1
With Target
.Select
.ClearContents
Call UnMergeCells2
Exit Sub
Call MergeCells2
Call MergeCells2
With Target
.Select
.ClearContents
