I have 2 worksheets.
1) Warranty.xlsx - To track a product sent out to OEM for repair.
2) Database.xlsx - Production rejects information.
3 column, P, Q and R, were added in the database.xlsx.
These columns will check whether the s/no. and date code match in the warranty.xlsx and record the information as follows:-
1) RMA Before, P column - Yes means send out for repair before. "-" means never.
2) Warranty expired date, Q column - if P column ="Yes", stated the expired date, 3 months from the "Date of Return" in the warranty.xlsx. otherwise "-".
3) Warranty, R column - compare Q column and current date to check is the product overdue or not due.
I need help in:-
1) P column - "Yes" when both the S/No and date code matched.
2) Both workbooks kept in the same directory. how can I move the workbooks to another directory without changing the formula each time?
I need help in:-
