    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Replicate data in blank cells
Discussion in 'Ask an Excel Question' started by sureshmandadpu, Jun 11, 2018.
  1. sureshmandadpu
    sureshmandadpu Member
    39
    Dear All,
    I posted my query in the attached file. Can any one please help?
    It should compare Location, Department and Clients and see who has more details and ensure totals are tallied and give one common output which enables to pivot the data.
    M. Suresh
  2. vletm
    vletm Excel Ninja
    4,675
  3. GraH - Guido
    GraH - Guido Well-Known Member
    908
    would you have Power Query onboard? (Get & Transform?) -> attached file.
    RE-EDIT:
    Manual alternative (EDITED, did not notice the freeze panes and hidden rows):
    In the column B select all the cells, then via GoToSpecial select blanks. Then type in cell B7: = B7 and press CTRL + Enter. It will fill down all blank cells with the preceding values.
    In the columns D&F do the same but use the formula in cell D4: = D5 to "fill up" the values.
    in G4: IF(E4="",C4,E4) and drag down.
    Add column H to correct client list, in H2 type: = IF (LEFT(A4,5)<>"Sales,"",F2)
    sureshmandadpu likes this.
  4. sureshmandadpu
    39
    Sorry Sir for creating confusion. My sincere apologies.
    In the attached file, I gave data transaction wise. So, we can analyze how output came.
  5. sureshmandadpu
    39
    Sir, you are ultimate. This worked for me.
  6. vletm
    vletm Excel Ninja
    4,675
    sureshmandadpu
    Hmm... no answers
    ... but seems that Power Query works.
  7. sureshmandadpu
    39
    Sir, I sent you revised file. Could you please check it?
  8. GraH - Guido
    908
    Glad you liked it. I assume referring to PQ solution?
  9. vletm
    vletm Excel Ninja
    4,675
    sureshmandadpu
    I checked it twice!
    #4 version has two empty rows between some ... groups.
    and now Client-column is empty...
    I didn't find any answer of my questions:
    Why sometimes 'green' values are from C and sometime from E-column?
    Where comes those 'yellow' values ... from above or below?
    or
    Where did You answer to my questions?
Share This Page
