Replace Numbers with Letter
S P P
bosco_yip
Thanks for the answer
Not translating TEXTJOIN
Can you replace
INDEX & MATCH or the function VLOOKUP
bosco_yip
bosco_yip
Can you replace
Then, use the old day method,
In D3 formula copied down :
=SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(B3,1,E$2),2,F$2),3,G$2),4,H$2),5,I$2),6,J$2),7,K$2),8,L$2),9,M$2),0,N$2),".",",")
Edit : the above formula has fixed (in replacing 0 with "X" as per the OP's comment)
bosco_yip
bosco_yip
Zero is not replacing with X
Sorry, my mistake,
here is the fixed of the formula :
S P P
bosco_yip
keep it up
The end X is missing, but before the end it replaces
$125,30 UDC,T
$120,30 UDX,T
bosco_yip
bosco_yip
keep it up
$125,30 UDC,T
$120,30 UDX,T
Then,
Use this formula as replacement :
=SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(TEXT(B3,"#.00"),1,E$2),2,F$2),3,G$2),4,H$2),5,I$2),6,J$2),7,K$2),8,L$2),9,M$2),0,N$2),".",",")
74939
deciog
SPP
For the Brazilian Portuguese version of the formula, you have to change the format of the TEXT function, where this "TEXT(B3,"#.00")" changes to "TEXTO(B3;"#,00")", Comma
Hope this helps
Hugs
decio
S P P
bosco_yip
TEXT(B3,"#.00")
I just needed to change the semicolon
TEXT(B3,"#,00")
Worked perfectly
Thanks a lot for the help
deciog
Muito obrigado por participar deste tópico
Já tinha feito a substituição, mas mesmo assim valeu.
