Replace file in same path and with same name
hsm123
Requirements:
  1. Protect all sheets
  2. Hide all sheets except PERMISSIONS sheet
  3. Add password to the file and save it in the same path with same name without prompt
The below shows an error saying to replace the file extension. I am currently using the binary format and to save the file in binary format only.
Private Sub Workbook_BeforeClose(Cancel As Boolean)
Dim a110w As Variant
Dim path As String
Dim fName As String
a110w = "123" 'P
path = ThisWorkbook.path
fName = ThisWorkbook.FullName
      ThisWorkbook.Unprotect Password:=a110w 'Unprotect worbook structure
     For Each Worksheet In Sheets 'Protect all sheets
          Worksheet.Protect Password:=a110w
     For Each Worksheet In Sheets 'Hide all sheets except PERMISSIONS sheet
         If Not Worksheet.Name = "Permissions" Then Worksheet.Visible = xlVeryHidden
ActiveWorkbook.SaveAs Filename:=path & fName, FileFormat:=50, Password:=a110w
ActiveWorkbook.Close savechanges:=True
Possibly...
    Dim sh As Worksheet
    Dim fName As String
    Const a110w As String = "123"
    With Me
        fName = Left(.FullName, InStrRev(.FullName, ".") - 1)
        For Each sh In .Sheets
            If Not sh.Name = "Permissions" Then sh.Visible = xlVeryHidden
            sh.Protect Password:=a110w
        Next sh
        .SaveAs Filename:=fName, FileFormat:=50, Password:=a110w
Possibly...
    Dim sh As Worksheet
    Dim fName As String
    With Me
        Next sh
Apologies for coming up after a long time. Just found out the code does not work properly if the file name is "abcd_v1.0". Is there a way around we could fix this issue?
Basically to make a save as irrespective of the file name containing a special character or not.
