Repeat row values in a specific number of times with specific pattern
syp1677
Please find attached a sample file.
Based on the cell range B2:C13 (with the understanding that some cells B4:C13 are blank), I want to have a specific pattern as described.
I am using Excel 2016, hence some of the functions of 365 won't work in mine.
Your help is highly appreciated.
Regard,
S
  • Sample14012023.xlsx
Try to set up as per attached file.
1] Give criteria of "Min. repeated number of times" :1, 3 and 9
2] Result of "repeated number of 1" in G2 formula:
=IF(ROW(A1)<=SUM($C$2:$C$13),INDEX($B$2:$B$13,MOD(ROW(A1)-1,COUNTA($B$2:$B$13))+1),"")
3] Result of "repeated number of 3" in K2 formula and copied right to O2:
=IF(ROW(A1)<=SUM($C$2:$C$13),INDEX($B$2:$B$13,INT(MOD((ROW(A1)-1)/I$2,I$2))+1),"")
All copied down.
82445
  • Serial Number.xlsx
Thank you Bosco_yip for the response. Great formulaes...
I have encountered one problem if the B4:B13 have formulaes then column G shows different results.
82450
If B4:B13 have formulae and contain formula blank.
In G2, try to use this copy down formula instead:
=IF(ROW(A1)<=SUM($C$2:$C$13),INDEX($B$2:$B$13,MOD(ROW(A1)-1,COUNTIF($B$2:$B$13,"?*"))+1),"")
Thank you Bosco_yip
It worked perfectly fine.
Explanation of the said formulae will be highly appreciated..
Thanks a tons..
S
Good catch, please find the revised as in:
1] In K2 revised formula copied down, and copied formula to column O:
=IF(ROW($A1)<=SUM($C$2:$C$13),INDEX($B$2:$B$13,INT(MOD((ROW($A1)-1)/I$2,COUNTIF($B$2:$B$13,"?*")))+1),"")
2] G2, formula not required array entry.
3] Please see revised file
82466
  • Serial Number (1 revised).xlsx
