rename - split up multiple underscore formula help
jk51
need help on create excel split formula on how to get remove after the 4th underscore to the right.
For example
H1_1_12i_P_8-19yrs change to H1_1_12i_P
H2_3_01i_P_75+ change to H2_3_01i_P
H3_5_48i_M_under 20 change to H3_5_48i_M
Thank you,
Mr Singh
AliGW
Remove or return?
Is this what you want?
=SUBSTITUTE(TRIM(LEFT(SUBSTITUTE($A1,"_",REPT(" ",100)),(100*4)-1))," ","_")
Or is it this?
=SUBSTITUTE(TRIM(MID(SUBSTITUTE($A1,"_",REPT(" ",100)),(100*4)-1,1000))," ","_")
