Read-only & read write access for specific columns in excel 16
akika
Pls help.
I have an excel doc in a share drive and 5 users have access to it.
I want that specific users e.g Kim, Kate and akika to get read-write access to the excelsheet column A to G
and other specific users (Sam, John) to have read-only access column H to L.
How can i do that pls?
Thxs.
Ive tried and for the first range its ok only user mention in list can edit.
Cell A TO G10 editable.
But once i select the first range, the option Allow users to edit ranges is disabled and i cannot make the cell H to L editable for another set of users.
is there somthing else to do??
cell A to G10 should take range 1
e.g Kim, Kate and akika to get read-write access to the excelsheet column A to G .. and they shouldnt be able to edit column H to L
Cell H to L should take range 2 config
e.g (Sam, John) to have read-write access column H to L but read-only for column A to G
yes i hve access..
Ive set my name in the range 1 permission for cell A to G10.
If i try to input in cell a12, then i get the message that cell is protected.. which is ok.
But if i try to input in cell H then its allowed .. which shouldnot be the case.
how should i make cell A to G take range 1 and other cell H to L range 2.
As when i select the first range, the option Allow users to edit ranges is disabled and i cannot make the cell H to L editable for another set of users.
Any idea?
