Raw data to in pivot and vlookup using macro
webmax
Dear Team,
Attaching the sample file . Which contains three sheets
1) Dashboard
2) data
3) Pivot Table.
My required macro is the Raw data to be make as pivot table. From the pivot table the same has to put as v lookup in the Dashboard file.
The raw data change then the pivot and dashboard file also to be change if i run the macro.
Shahul
  • sample data for macro.xlsx
Hi:
Why you want to create a pivot for this? Can't you a simple sumif function (like below) in column D of your Dashboard tab?
=SUMIF(Credited!$C$2:$C$4,B2,Credited!$G$2:$G$4)
