Ranking a column of averages from 1st to 24th
Rory2010
I'm pretty much a rookie at excel but learn quickly.
To be completely forward I am making excel spreadsheets for my fantasy football league
and we want something we can track, organize and have readily available for viewing each week. Plus to be able to have all those stats going into each new year.
So I am averaging the scores each week for each player in the list.
I am seperating by one row, each sub group (QB,RB,WR,TE,K,Def)
I have a column of averages that I want to take from one page and display on another as a "TOP 24 PERFORMERS" averages from 1st to 24th.
I've been playing with AVERAGE,LARGE AND RANK for hours and want to see if I can get a hand in the correct direction.
All help would be greatly appreciated!
Rory
Hi Rory,
Have you tried to SORT the column of averages, this would give you the data in the sequence that you want it.
Cheers
kanti
Well I needed a formula for the table I want to use on the "Top Performers" worksheet.
I have got this to work =LARGE(ROUNDDOWN('2010'!$D$3:$D$5,0),$A14:$A37)
"2010" is the sheet I'm pulling from
$D$3:$D$5 is the 1st group/array
$A14:$A37 is the list from #1-24
My problem is I can't get it to combine my groups/arrays
I've tried to add a second array but these won't work
=LARGE(ROUNDDOWN('2010'!$D$3:$D$5+$D$8:$D$13,0),$A14:$A37)
=LARGE(ROUNDDOWN('2010'!$D$3:$D$5+'2010'!$D$8:$D$13,0),$A14:$A37)
=LARGE(ROUNDDOWN(('2010'!$D$3:$D$5)+('2010'!$D$8:$D$13),0),$A14:$A37)
Do I need to use a SUM or some other function to combine the arrays?
Any help would be appreciated!
Rory
Why not just use
=LARGE(ROUNDDOWN('2010'!$D$3:$D$5+'2010'!$D$8:$D$13,0),ROW(A1))
and copy down
I tried that and I get a #N/A and "A value is not available to the formula or function"
All cells in the formula have values in them???
I tried these and all the same:
=LARGE(ROUNDDOWN('2010'!$D$3:$D$5+'2010'!$D$8:$D$13,0),ROW(A1:A9))
=LARGE(ROUNDDOWN('2010'!$D$3:$D$5+'2010'!$D$8:$D$13,0),ROW(A1:A24))
I still think it's something to do with combining more than 1 array.
It doesn't read it correctly.
Rory
can you post your file somewhere so we can have a look at it
For guides on where and how to post files read:
http://chandoo.org/forums/topic/posting-a-sample-workbook
I just stuck it on my website for easy access
www.ilovebodyjewelry.com/prodimages/FantasyFootball-2010.xls
The "Top Performers-Test" page is where I have the formula.
Rory
Also since your going to take a look at it my next question would be, how could I get the "Player", "Pos" and "Team" to follow in the same row?
Thanks a Ton!
Rory
Rory
add the following equations
2010!AM3: =RANK(D3,$D$3:$D$37,0)
copy down to AM36
2010!D3: =AVERAGE(E3,G3,I3,K3,M3,O3,Q3,S3,U3,W3,Y3,AA3,AC3,AE3,AG3,AI3)+ROW()/10000
copy down to D36
'Top Performers'!B19 =OFFSET('2010'!$A$2,MATCH('Top Performers'!$A19,'2010'!$AM$3:$AM$36,0),COLUMN()-1)
copy down and across to E42
I tried those and I get #N/A accross the whole Top Performers table
AM3-AM36 cells show "2" in all of them.
Rory
I went back through multiple times from scratch and now I just keep ending up with
#DIV/0! error in the 2010!D3 row with the blank cells
and the AM column as well, with #N/A
Here's what I have maybe I did something wrong?
http://www.ilovebodyjewelry.com/prodimages/FantasyFootball-2010-2ndEdition.xls
You/we made 2 mistakes
1. Delete the contents of the cells in Column B with the ######'s, ie: the cells between each group
2. You entered the formula on Top Performers page as an Array Formula
You will have to select the whole area B19:E42 and press delete and then re-enter
B19: =OFFSET('2010'!$A$2,MATCH('Top Performers'!$A19,'2010'!$AM$3:$AM$36,0),COLUMN()-1)
enter it as a normal formula not an Array Formula
Turn calculation to Automatic
You are awesome!!!!!
Thank you sooo much!!!
Works Perfectly!
Just had to change =OFFSET('2010'!$A$2,MATCH('Top Performers'!$A19,'2010'!$AM$3:$AM$36,0),COLUMN()-1)
to
=OFFSET('2010'!$A$2,MATCH('Top Performers'!$A19,'2010'!$AM$3:$AM$36,0),COLUMN()-2)
to get the players names in and move it over one more column.
I can't thank you enough!! :)
Rory
